Tractorcedric
- Location
- Garland. Utah
The old hub that has the springs and detent balls in it is smooth on the outside. JD drilled blind holes from the inside for the springs to fit in. The new aftermarket hub was drilled from the outside. Then they put plugs in the holes. The end of these plugs stich out and just barely hit the edge of the syncro drums. Should I just file them so that they clear or drive them in some more?
<image src="http://forums.yesterdaystractors.com/photos/mvphoto10044.jpg"/>
