Ignition issues on Model A
cogosser
New User
I have an early 40's Model A that I am having issues with the spark. If I pull the plugs and ground them to the frame and crank the engine I have 2 sparks on the left side plug. It has a WICO distributor that was rebuilt with new points and coil. It is a distributor nor a Magneto. Even when I completely remove the right side wire from the distributor, I can still get a double spark on the left side plug. I am thinking I have a cracked distributor cap, but I do not have the tell tale black trace across the contacts. Anyone have any ideas?
I guess I'm not following you ? That model even with a mag. fire on both TDC of compression and exhaust. So they normally spark 2 x ?
Those WICO Dist. were not know to be very good. The Delco Remy is the preferred unit.
[Doesn't the distributor turn at half the speed of the crankshaft? If it does, each plug should only spark once, TDC of its compression stroke.
Why am I getting the spark on the #1 plug on its exhaust stroke?
That model they turn at crank speed.
The crank turns the larger cam gear so that is 1/2 speed, then the cam gear turns the smaller governor gear taking it back up to crank speed.
Models like the 520 thru 730 gas all run the dist. off the cam.
TDC Exhaust stroke spark is for that side and should be there for these double hit girls. Every TDC. Technically called waste spark system it is also used on pony motors and a good number of modern cars too. It's an honest to God real thing and you've got it even if you didn't know it before this point. Sounds like this might be news to you and maybe it's not cross-firing at all?
The Waterloo and first number series tractors whether they have magnetos or Wico or Delco distributors fire on both compression and exhaust TDC. The ignition system is driven by the governor gear at crankshaft speed. Vertical distributors on two cylinder 20 and 30 series turn at one half crankshaft speed. LP tractors of first numbered series also turn at half speed.
When you say "two sparks" do you realize it fires at TDC on BOTH the Power and Exhaust strokes??? That's IF it has a Wico C or X Magneto or the Wico distributor you have. That's so if you remove one or the other plug wire, the one firing will still fire on BOTH TDC's.
You mentioned "left side plug" it should do the same on the left and right. If you ONLY have fire on one side but not the other, there could be a wire or plug or cap or rotor type or else another problem.
John T
