farmerjack
When replacing the axle seals in the 42 A, will I be required to replace the bearing cones and cups even if they are good? I have done this on a couple of similar vintage Bs and I had to weld the inner cups to get them to come out of the axle housing, so I replaced all the bearings to have them run in together. Any tips for replacing the seals, bearings would be appreciated as I see the felt seals/assy are a little different than my 45 and 43 Bs. Also I plan to use National brand seals. Is this one of those places it has room for two where the original is wider?
Again hoping to make this a simple weekend project to enable the tractor to be used quickly. It has to earn its keep as it won't just be a parade queen.
thanks.
thanks.
