D Blattner
New User
I bought a 1020 with manual steering, unfortunately, it also has a loader. While I like the tractor, it is hard to steer with a full bucket.
I have seen the add on PS it also says not good for use with a loader. I take this to mean the pump is too small for the loads and pressures it will encounter with the loader.
Is it possible to add factory power steering by adding the PS column and tapping into the hydraulic lines for an oil supply and pressure? Are the columns the same bolt pattern? Or is there more to this than I understand?
