John Deere A powerlifrt
Does anyone have a idea where to located a powerlift for a 1934 A? I have a 2way plow and I am in need of a lift. Any leads would be great. Thanks.
Ive seen people take one off a later model and bolt on and worked just fine. Don't really know if year modle makes a difference don't think so, I even had one on a 37 model. Get more input on this subject.
A later one is a bit different, but will fit. A very early one might be tough to find.
I forget, does the '34 A have the standard 1 3/8 PTO? If so, I think any power lift rear cover from a 40's A will work. My '36 A had a power lift from a later tractor added at some point.
The correct one would be a single small pedal lift. If you're on Facebook, you might try the "Two-Cylinder club of Facebook" and post what you're looking for. If not I would do it for you.
I don't know what will or will not fit, but my neighbor has a nice old long hood slant dash A with a lever operated powertrol. It's noticeable with the pan seat. If I were gonna change things, I'd see if the powertrol would fit.
If I am understanding you correctly, currently you have a FLAT Back tractor, your going to need the whole house that
includes the rock shaft with a power lift??
