Charles Branch
I recently bought a 2355, which is pretty new by my standards. After sitting a few months it would not start--not even a click of the solenoid. I charged the battery and cleaned the battery cables, but still no results. It starts just fine if I jump the solenoid. I once had an intermittent starting problem on my 2130 that turned out to be a loose connection on the neutral safety interlock switch. I assume the 2355 has a similar switch, and I think I remember the seller telling me that the clutch also has to be depressed. Are there any other similar interlocks that I should be checking? I only used the tractor a few times last fall, and I recall once before having trouble starting it and then remembering something stupid that I had just forgotten to do.
