Need a set of mounting bolts for 530 3 pc front weights
Randy G
Looking for a set of mounting bolts for the JD front 3 pc weights for a 530. Left side A5347R, Right side A5346R and front weight A5345R. Any help is welcome! Thanks.
Randy : bolts that attach right & left side weights are common hardware, 5/8 x 2&1/2" & 4" gr.5 mach. & carriage bolts.. front weight use 2 A-5352R special nuts, available from deere (attach to stud on front or tractor) 2 studs A5321R not available, [need to make them] ; & 1 F3042R bolt , 3/4 x 5&1/4 available.. Take look at PC527 on JD parts .com / hope this helps..
www.greenpartsofva.com or 540-460-3386. George reproduces those bolts. Great quality in his work.
