johndeeregreg
our 730 will miss on 2, if i pull the plug wire out of the distributor cap and hold it against the cap right at the to where wire goes in it will shoot the spark up to the wire and fire, i can then put wire back down like its suppose to be and it will keep firing but drops that side when a load is applied. what should i check first? i haven't spent any time checking condition of wire end or cap but cap has been replaced in the last year and a half and the wires aren't that old either. has pertronix electronic ignition and coil, copper wires, and autolite 3116 plugs. i have been told that carbon core plug wires should be used with the pertronix systems but i'm not sure why.
