Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
420S hydraulic problems
Case1950
01-13-2018 07:26:15
My 1957 420S 3 point is acting strange. The 3 point will not lift up much and is very weak. When selected down it shoots hyd fluid out of the fill. I just took the pump off and everything looks good.
Any suggestions,
Thanks
Case1950
M-MAN
01-13-2018 16:57:24
 Re: 420S hydraulic problems in reply to Case1950, 01-13-2018 07:26:15
Foamy oil in a Dubuque and poor lift function can usually be cured by getting rid of the oil that's in there and replacing it with 20wt or 30 wt NON DETERGENT motor oil. Foam is air and it's usually getting in there at the joints on the large suction line. Each joint has a rubber seal that you may be able to tighten up or you may need to replace. Seems like the seals are about $8 each at Deere. JMO
CPeter
01-13-2018 15:28:10
Make sure you use NON DETERGENT engine oil in it. Detergent oil is the cause of many problems with these. One reason to use engine oil is because if you have a seal leak in the pump, the oil ends up in the crankcase. You will know if that is happening when the oil level keeps getting higher for no apparent reason.
Sometimes, a good flush with kerosene helps, but I won't recommend that even though I have resort to it on occasion.
CPeter
JD Seller
01-13-2018 09:13:19
Run it and look at the hydraulic oil. IF it is foamy looking , like I think it will be. You have a valve leaking on the high pressure side. So the lift will not lift and the oil gets foamed up and runs out the fill hole. If it is you will have to take the lift controls valves apart to see what is wrong.
I have not had one of them apart in 25 years or more. So I can not tell you off the top of my head how/what to do get it apart. I worked on a fair amount of these back in the late 1980s as guys started collecting them and wanted everything to work.
case1950
01-13-2018 13:13:47
 Re: 420S hydraulic problems in reply to JD Seller, 01-13-2018 09:13:19
You are right, the oil is foamed up. I have a shop manual hopefully Iíll figure out how to take the valves out when I get home.
Thanks for the quick reply
