JOHN DEERE A - CLUTCH PULLEY REBUILD
illbdipt
have been shopping for parts.cant find the bearing and the bronze bushing inside the pulley.anyone know where they are available ???
Have you tried ordering them from a John Deere dealer ? Used to not have any problem getting them.
DEERE still has the bushings, NOT sure which # bearing you need since you didn't post a serial number.
With the serial # you can go to www.jdparts.com and download the correct parts catalog (in .pdf format) and get the bearing numbers, and do a GOOGLE search.
Below is a link to ONE post here on YT on the subject.
Bearing thread
(quoted from post at 12:24:07 01/05/18) have been shopping for parts.cant find the bearing and the bronze bushing inside the pulley.anyone know where they are available ???
The bca part number is MA1208EL oriellys got mine for me comes with inner race that goes on the crankshaft.
thanks for all the leads. will track down a bearing and bushing this week. clutch disc's are ordered. will post back when finished, or if need of guidance - which ever comes first haha.
what is the torque spec on the bolt that holds the clutch driver on the end of the crank shaft?? ordered the bronze bushing at my local john deere dealer this morning and the bearing off of e-bay.
Very few bolts on these old 2 cyl. have listed torque values. I use a chart that lists torque by bolt size and then use the grade 5 value on the 2 cyl. bolts.
