when is spliiting a 3020 necessary?
chas036
I am in the market for a 3020 and I just curious for what problems or repairs that splitting the tractor is absolutely necessary? Obviously I know for clutch work you have to split it, but can all the hydraulic pump work and transmission work be done without splitting the tractor?
The hydraulic pump is in the front of the tractor under the radiator, the charge pump that feeds the main pump can be removed by lifting off the rockshaft, to rebuild the upper trans shaft,or any other gear work,or pto brake requires a split at the trans/ bell housing. Pretty much the same for a powershift.
