45 loader axle brackets for JD-B
I need prints or specs on axle brackets for a 45 loader to fit JD-B tractor. Cant find them so have
to make them. Pictures are good but like to have dimensions.
Look at farm/consignment auctions. They frequently turn up their for scrap prices. Don't think there is anything special about brackets for your B. All I have seen are basically the same, some have extra bracing but bolt patterns are the same although brackets made to fit other makes like Farmals might be different.
Stanley - you can download the parts manual for your loader for free from Deere. It will give you some ideas on where to start.
I have one mounted on a 630 - if you need some measurements, I'll try to help. It may be different than your "B", but I'm pretty sure my loader will fit either tractor.
Thanks, I will try to get prints from Deere. Im sure I could fab it but like to have some
measurements. Plate thickness, "U"channel thickness, length/height and bolt pattern. Pin location.
Mounting hole sizes.
Stan
Stanley - let me know exactly what you want measured and I'll try to help. I can get you pictures too.
No help from Deere other than pictures in a OM so far but I think they are looking for more
detail info. If I could find a set I could take measurements for fab work. All the junk yards
I contact say none available and good luck on finding them.
Stanly - poster 36A has the best idea for you. In addition to getting the brackets, you'd have other parts for future use, all for $100 and getting it home. I bought part of one for parts for $40, but it didn't have the mounting brackets.
I sent an e-mail to you about getting measurements/photos off of mine.
