gear reduction starter
Mike Aylward
I have been trying to research whether or not there is a gear reduction starter available for my 70 pulling tractor. I know the bolt pattern is different from previous and later tractors. Is there a starter that will bolt up or will an adapter plate be needed. Any help is appreciated. Mike
The reason I am asking is I saw a video
where a company has a gear reduction
starter for a late A. I would like to
find a similar starter for a 70. I
can't go 24 volts due to weight of an
extra battery and compression releases,
while a possibility, are not that
easy given the setup I have. Mike
There is an adapter plate for just that purpose. Email is open. I can get the names of those that have them for you.
