6400 power steering cylinders
Any advice in replacing seals? I don't see how the cylinder comes apart or what holds the shaft in (no retaining ring or cap). Do I take off the wheel side and pull the shaft out?
Take it off on the wheel side but .leave it attached to tractor side. Remove the hydraulic hose and look inside barrel. At the end of the rod is a retaining ring. You can work it off with a screwdriver or pick through the hole and then pull the rod out.
