Mnethercutt
It's 10 degrees here, which is about as cold as it ever gets, and I wanted to see if my 1010 would start this cold. It did, pretty well actually, but when I went to check my oil pressure it was well over 120PSI. Normally when I start it up it's running at 60. 10 seconds later I see oil on the ground and now theres oil running out of the filter base between where the metal shield goes over the filter and the base. I know there is a gasket there but I replaced it not more than a year ago. Did I just blow that gasket? Should I have tightened the shield down more?
See attached picture. This is not my filter, just a picture of one from eBay.
