TractorLinks.com
Show Parts for Model:
G pistons
Chadz
01-01-2018 18:32:18
I have a 52 g. I pulled the Pistons out and they have a number on them that I haven't seen before. It has a A1241 on the inside of the piston it also has WMW on them. They are aluminum flat tops. I would like to find new rings. I cleaned them and I can't find any size on them. Thanks for the help.
buickanddeere
01-03-2018 07:57:17
 Re: G pistons in reply to Chadz, 01-01-2018 18:32:18
When you have it apart this far . How about having that worn camshaft re-ground to match the pistons ?
Chadz
01-02-2018 16:29:17
There was no ridge in cylinders. I honed both and they look very good. I will have to check the gaps on the rings, what do they need to be.
Bob
01-02-2018 19:42:01
 Re: G pistons in reply to Chadz, 01-02-2018 16:29:17
There's some helpful tips on ring fit in the grooves, plus end gap at the link below.
Might not be a bad idea to give Dave a call for any specific recommendations for your relatively large-sized piston.
buickanddeere
01-02-2018 04:20:44
May as well measure the bore and ring end gap when it is apart . How much ridge in the bore ? Just purchasing new rings and slapping it back together maynot workout as well hoped . How much of a rebuild are you planning and what is the tractor used for ?
Bob
01-01-2018 20:00:22
Whatever those pistons may be, Hastings or Dave Reed can supply you with rings. Measure 'em up so you know what you need.
