JD distributor mounted hydraulic pump rebuildable?
Randy G
Hopefully the pics load. Are these pumps rebuildable? I find no info online and was hoping I could rebuild it. If not me is there some one that can rebuild it for me? The pump in the pics are not the unit I have coming but is the same type A4754R.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto8399.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto8400.jpg"/>
I haven't speced the gears but I wonder if they are the same as in the PS pump on the letter tractors. In my opinion the wear would be in the gears and housing and without a ton of money I couldn't see how this would be affordable. Now having said that if the gears only had the wear you could possibly find a source for these...I would think bearing would be available...I'm not sure of the pressure rating but I would think it comparable to the power steering pump when in good shape.
The rebuild information is in the power-trol service manual. The parts breakdown is in the late A or B parts manual. There is not a lot to rebuild. The small seal is a vacuum side seal so it need to be installed correctly. You may need to use a speedy sleeve under the dual seal because the shaft seems to pit in that area. The drive collar may have the corners worn off so look them over closely.
