A4648R connecting rods for an A
Looking at some 4648r rods with the Insert bearings I know
You can by undersized bearings but do you use shims also my crankshaft is in between sizes and I'm trying not to pull the crank if possible thanks
Use a Micrometer and/or plastic gauge and go according to that. Crank probably wont be round so watch for tight spots like when you shim the Babbet rods. I have seen half an undersize bearing in them as well .No you don't shim the insert type rods .
