1010 Rear Panels
Trying to install the rear panels (the ones on the side of the hydraulic pump/cowl panel) but I can't get the dern screws to lock them in. SN25990 so I don't have the spring the help hold them in. Anybody got any tips on how to get those screws in? Every time I try to screw them in w/ a knife or something I end up stripping paint and I"m tired of messing up the panels.
Mine were terrible the first time I took them off. Used the impact screwdriver. I cleaned up the post and roll pin on the panel with a metal brush and then did the same on the holes which was a bit tedious. I then put anti-seize on both parts. They come on and off much better now.
From my MT I had an old screwdriver I had found that worked well on those screws. It was a much larger face than what you can find most places. That also helps out quite a bit.
