mr.precision
Recently brought home a pretty nice 420W that hadn't been run in several years. Carb was full of debris/rust, so I cleaned in and installed a kit. The tractor started right up, makes good oil pressure and doesn't smoke. The tractor will not idle well unless the idle screw is turned all the way in. Looks like I didn't get the carb cleaned properly. I could not remove the main jet as it was stuck. Any tricks to getting this out without ruining it? I did get the power jet out OK and cleaned all the passageways in that area.
Second question concerns the throwout bearing carrier. My 40T has a grease zerk visable through the inspection port. The 420 doesn't. The shaft that the assembly slides on is dry. Any thoughts on what's going on? Even the shop manual shows a zerk in there.
Thanks in advance.
Thanks in advance.
