I have a cam gear on a JD 70 that has a whole bunch of broken teeth. I have the tractor all ripped down to where the cam is loose from side to side. How do i get the cam bearing off the end of the cam so i can get the gear off?
Is there some kind of special bearing puller that will remove the bearing thru the case?
I do not want to have to remove or will i remove the crank to get the cam gear off.
I will take some picture tonight so show where i am at in the process.
