3010 shift lever
Olliejunkie
My shift lever had been broke since I bought it years ago but still works. I am searching on eBay looking for one. My cast number is r263873r. I keep finding them with cast number r33772r. Does anyone know if they interchange? Thanks, P
I think my number is r26397r. Think I read it wrong. Here's some pics.
You can go to www.jdparts.com and look up parts
and it will tell you if and what number the current
part number subs to
Thank you. I didn't see a sub but they wanted 170 for the lever. I will look again. Must be different. I think the one is for 3020.
I think they are the same as a 3020,and your last part number is correct,,for some reason I can't get on the
Deere parts site right now..
3020 is the 3372... number. It's more money but I found a good deal on one. Wonder what the difference is?
Ollie, If it is a synchrorange transmission, I would put the long, curved shift lever on it. They were on the 71 and 72 3020 and 4020. They retrofit the older tractors.
(quoted from post at 06:25:34 12/29/17) Ollie, If it is a synchrorange transmission, I would put the long, curved shift lever on it. They were on the 71 and 72 3020 and 4020. They retrofit the older tractors.
Are you speaking of the main shifter? What is the benefit of changing it? I am working on the lower levels behind the battery.
