Costs to O/H our '72 4020 this spring were close to $7K CAD.
$2400 - Reliance high compression O/H kit
$660 - New Stanadyne injectors
$1100 - Machine shop costs(cyl. head reconditioning & small end bushing replacement / re-sizing)
$2500 - [b:c261839941][u:c261839941]Misc.[/u:c261839941]
[/b:c261839941]
The miscellaneous costs are a combination of the unexpected wear items found during disassembly & of the small items required in a quality O/H:
Water pump overhaul
Thermostat replacement(resurfacing of housings due to possible warping)
Oil cooler testing or replacement
Radiator cleaning / testing or replacement
Radiator hose/s replacement
Heater hose/s replacement
Intake hose/s replacement
Block heater & cord replacement
Unexpected items: push rods & lash adjusters worn due to migrated rocker shaft end plug, oil pump pick up screen loose, oil cooler & heater hose steel piping corroded
Items replaced due to age & importance of operation: Coolant temp. gauge & low oil press. light switch
Note that the above is only parts & machine shop costs as I did the work myself. You could plan on close to similar costs for labor($6 - $7K).
USD will obviously be significantly less, situations vary, & there are cheaper routes to take than what I've posted but most with experience will point out that taking the cheap road usually doesn't pay.
All it takes is a groggy operator & a "ratty" radiator hose that blows / fails under full load to cause a major overheat condition, negating a fresh overhaul.
FWIW
(quoted from post at 13:22:39 12/24/17) I am not needing an overhaul just yet, but I know the time will come. If the complete major kit can be bought for $1500--1700, then can someone tell me why it usually costs more like $4000-$6000 by the time it is all done? What is a rough breakdown of the other costs besides the kit?
quote][/quote]
