4020 1964 synchro going back together between trans and clutch housing. Got it to where the dowel pins are started and
bolts even screw in about 3/8 inch. About 3/4 inch of space to go. PTO gears in mesh and turn. Input shaft to trans
seems to be in mesh, and turns trans top shaft. Still turns it when I back housings apart another 1/8 inch, so almost
has to be started in the hole. But it gets tight and flywheel does not want to turn if I start to draw the bolts in
more. I have tried all the tricks I know, jacking here, then there, tighining here, then there. How much pull does it
usually take with the bolts to get it in the rest of the way. I dont want to break anything. Advice appreciated!
