I?m working on a 37-38 John Deere H.
It started running bad and I?m having trouble getting it to run right. At idle it backfires randomly thru the carburetor. If I try to speed up the engine it backfires a little louder thru the carb and engine doesn?t really want to rev up.
For a history of what I already did to this tractor.
When I got the tractor is wasn?t running but it was in fairly good condition. I pulled the head and pistons honed the cylinders and installed new rings. The head was cleaned and valves lapped. Cleaned the points and bought a new coil for the magneto. I happen to have a new carburetor from a 35hp Wisconsin engine, so I made an adapter only for the purpose of testing the JD engine. It really ran good and smooth with the modern carburetor, but once I knew everything was good, I rebuilt and installed the original carburetor. Once I put the original carburetor it still ran good, but sounded more like a JD H should.
Tractor sits in a garage and I would start and run it a few times. About 4 months after I did the ?overhaul? on the engine, we had the flooding from Harvey near Houston. With all the work I had to do, the tractor got left in a building that got about 40inches of water. Before the water got high, I did manage to remove the magneto for safe keeping. Tractor sat in water for about a week. After the flood, I drained the oil, powerwashed everything. Gas tank was completely dry, no water. I took apart the carb and cleaned it very good. I put everything to together, regapped the points, started it up, but now I?m getting the backfiring thru the carb which I never had before. Timing is aligned with the mark and its firing on the right cylinders. I thought it might be the plug wires, so I put some others on it (solid core). Adjusting the carb doesn?t help, so I tried the extra carb. And it was still backfiring. I?ve run it this way for about 30 minutes thinking there may some crude on the valves since water got in the cylinders. Valves are not sticking and compression feels strong. Spark is good. I don?t know whats wrong. The only thing I can think of right now, is I accidently dropped the distributer cap of the magneto on the ground, maybe it has a crack that?s allowing the spark to jump inside. Anyone have any ideas on whats wrong? Any help would be appreciated. Thanks.
