Wildride47
Needs some advise what might be happening. Was plowing the drive today and lost power and hydraulic operation while moving down the driveway. Steering pressure, loader and 3 pt was also out. Let it sit and run while I checked things over and had power again when I got back on. Took about 3 minutes. Tried to finish the drive and it happened several more times by the point when I got it back in the barn. Oil Levels looked good, no leaks or heat found. Oils looks clean and did not have a bad odor. I had full power and all hydraulic operation when it came back up and ran. Any thoughts? I’m thinking I may have a blocked filter.
