3020 wiring question
ALAND
Working on repairing the wiring harness for my '67 3020 gas tractor. Can someone tell me where the wire for the 12v outlet is suppose to connect. Mine goes under the platform and is broken and I can't see where it needs to go from there. Does is go all the way back to the key switch? Thanks in advance.
Looks like it connects to the starter relay through an in line fuse.
Seems like on my 4020D it hooked right to a battery. When I rewired the 4020, JD supplied two little round circuit breakers and a bracket to mount them at the starter. Thereafter auxiliary power was run from there.
