4010 front pto
Earl T
I have transmission oil running out thru the center of the front pto stub shaft. Can someone tell me what has happened?
The front pto shaft has a bolt in it that loads all the internal pto parts. You must have lost it out and now oil is leaking down the inside of the shaft. There is a spring and some other parts that you may have lost as well. These parts have to do with being able to change from 540 to 1000 rpm pto. Look up JD parts to see the parts diagram for the pto shaft. Tom
Here's the parts that Tom refereed to that could be missing.
R36666 Dowel Pin - PIN,DOWEL ADD 3.25 USD
R27003 Washer - WASHER,ALUMINUM ADD 1.30 USD
R32121 Screw - SCREW,SPECIAL ADD 19.94 USD
R26686 Spring - SPRING ADD 3.59 USD total 28.08 USD
Thanks a lot guys. We was hauling manure and I noticed a line of oil in the snow. Got looking and and noticed where it was coming from and thought, that's a new one.
