I?ve got a 6310 cab I?m having trouble with Hydrolics pumping full stroke almost all the time (2900 psi) but while using it and pushing the brakes it?ll quit and go down to stand by pressure but the loader wont work like that but everything else does like it should only using only the pressure it needs but won?t raise loader with anything on it. Press the brake pedals and pressure goes up to 2900 psi until you press the brakes a few times then it goes to stand by. I checked rockshaft valve for cracks and priority valve and don?t see anything like that. I know it?s a load sense system but when it?s a standby doesn?t seem that there?s barely anything going to loader valve until you push the brakes and it goes to full stroke then everything works but seems to get a little warm on the back of the Hydrolics. Anyone have any ideas or had this problem? And yes the little dime valves or what ever the right name for them is are in there checked that to be sure. Thanks if anyone can help.
