37 D rear tire change out
Often it's easier to change a tire with the wheel and rim still on the tractor. There's less awkward weight to deal with. That's IF you have the equipment or luck to get the bead broke loose.
If you have cast centers, and it's necessary, the rim can come off of the center hub, which is much easier to deal with then the whole thing
Brandon
What is the rim width? From the factory 15-30 tires were optional . Converts to 16.9x30 or 18.4X30 depending on who you ask.
