Still need help on this one. Hopefully a picture comes through to clarify things. As you can see, the barrel on the left is recessed (stuck) back in there about 3/8 inch or so, with the balls rigid to the inside, not allowing it to accept the hose end. The barrel on the right is in the proper position and the springy balls will accept the groove on a hose put in it. There's no way I can see to grab on to the left-hand barrel to pull it out - if in fact this is what I should be doing. I've seen a plug-looking protrusion coming out the back of the valve casing, but I don't know if this has anything to do with it. Any suggestions and/or schematics that would help me get this corrected? Thanks in advance.
Cliff
Cliff
