JD 820 three cylinder front wheel
Charlie Sisk
New User
I have a 820 three cylinder diesel. The front wheels and tires are in bad shape. I want to replace both wheel and tires. What is the bolt pattern
and hub size for these wheels ?
Thanks
Charlie
The John Deere parts catalog shows the model 820 using two different hubs and four different wheels. The catalog shows the part numbers, but not the dimensions. I'm guessing that you should write down the serial number of your tractor and the current tire size----then look at the JD parts catalog.
To my knowledge all the hubs had a six bolt pattern with a six inch pilot hole. Make sure and get tractor rims and not implement rims. The center is heavier on the tractor rims. Also check the offset. Some tractor rims are not centered like most implement rims.
820s in the USA use the same 6 lug hubs as later model 1020s. 15" wheels are part # AN241667. Also available in 16" from Deere and others.
Case:G57046
David Brown: K905277, K907805, K914312
Ford:C5NN1007A, C7NN1007J, C9NN1007C, D2NN1007N, D2NN1007R29Z, D2NN1007S, E6NN1007BA
Int. Harvester:
3114166R91
John Deere:
AL68277, AL82488
Massey Ferguson:
1077570M91, 1660769M91, 1678319M91, 1678319M92, 1691618M92, 1693421M92, 1883333M92, 509893M91, 7011529M91
New Holland:
81816955
