TractorLinks.com
Show Parts for Model:
1946 John Deere A governor disassembly
1956eagle
12-04-2017 18:31:54
Can anyone tell me how to disassemble the governor from the governor case? Does the snap ring on the mag side have to come out first? Or should the whole assembly slide out once the gear cover has been removed?
John H.
MSD
12-05-2017 07:29:29
 Re: 1946 John Deere A governor disassembly in reply to 1956eagle, 12-04-2017 18:31:54
Try rocking the flywheel back and forth a little. It'll pop out then.
John T
12-05-2017 05:30:23
As I recall you also have to remove that oil line underneath that feeds the governor
John T
rla
12-05-2017 05:26:12
You would swear it won't come out of the left side of the housing, but It will, once it's turned right & you loosen the the flapper arm.
Gene Davis (Ga.)
12-04-2017 19:32:15
Be sure to remove the magneto or the distributor before you try to reassemble it. The spring will break it if you aren't careful.
1956eagle
12-04-2017 19:03:40
Thanks for the reply so quickly. I have unscrewed the fork from the shaft. The whole governor assembly seems to be solidly still in the case. I just wanted to make sure I had not overlooked anything before trying to tap the shaft out.
greenmech
12-04-2017 18:47:46
It will come out the left side, but you need to loosen the fork on the speed control lever. Ron Mn
