bmiller36
I'm looking at a 48 jd loader for my 3010. I'm wondering what I should look for it dual cylinders on the bucket ,and some have 1 cylinder . does it make a difference in valu. just wondering, thanks Bob
Are you asking if the #48 loaders have 2 bucket cylinders or one? I'm pretty sure JD#48 loaders do not have two cylinders on the bucket. There is only one on the center of the bucket.
OR are you asking if you should be shopping for a loader with 2 bucket cylinders?
The JD 48 loader only had a single cylinder for the bucket tilt. The JD 148 has two cylinders for the bucket tilt. The JD 148 loaders are selling in the $2000-3500 class depending on condition. A JD 48 loaders sell in the $1000-2000 range. The JD 48 loaders usually have damage around the single tilt cylinder mount, either on the loader frame or the bucket. If your going to use the loader much and can afford it look for a JD 148.
the guy says its a 48. I wasn't sure that's why I asked it has two cyl on the bucket so it must be a 148 thanks for your imput just going to cut and haul wood to the burn pile. Bob
