3020 questions
SVcummins
I have a few questions about the 3020 I just bought first will the duals off my 4020 have the same bolt pattern as the hubs for a 3020 ? The tie rod ends on my tractor don?t have grease zerks were they that way from the factory ?
9 bolt hubs are the same bolt pattern but 3020 has smaller rear axle than 4020 so different wedges are required for each model. IIRC factory tie rod ends had grease fittings.
