JD 4010 joystick
Hi all, does anyone know if it'd would be possible to plumb in a loader joystick on a 4010 with a 3- point and two hydraulic remotes. Also, if it is possible, does anyone know what needs to be done too make it happen. I'm trying to make this tractor a little bit more user-friendly for my grandpa. Thanks
It should be pretty simple, get a prince closed center two spool valve with joystick kit.
Pipe in at elbow near right brake pedal, dump into filter cover.
I agree with David tee into line in front of brake valve
For return one can return oil to RS return oil line.
Or ported hyd filter cover.
