Glen D Anderson and Step
2510Paul
Here are some pictures of the K&M Step Kit I put on my 4320. If these look hopeful I have 5 more pictures and I can dig out the K&M P/N.
Paul
Thanks for the pics. Paul!
I had found pictures of the K&M steps on one of the tractor parts websites a while ago and thought the mount looked like it might flex quite a bit due to the leverage from the design. That was the reason I passed on the K&M steps and tried to go with John Deere.
The step system I plan to build will tie into both sides of the factory cab mount hopefully keeping flexing to a minimum.
Will do.
I hope to get to it by spring but a broken spindle on the tractor in question has turned in to a complete front axle rebuild, mushrooming further into a steering motor overhaul. Then onto replacement of the load control shaft & bushings, bushing replacement in the drawbar support, wide swing drawbar repairs, PTO clutch valve reseal/repair, several hyd. leaks needing addressed, seat suspension overhaul with seat cushion replacement, reseal the various & numerous holes in the cab, install new cab liner kit, etc.
Add that to the other projects on the go & for some reason it turns into another one of those "roundtoits"? LOL
