What Model JD plow is this
I picked this up today and figured it was a good match for the old 60. Thinking about restoring it or using it as is. What model is this or where can I go to look for a part number. Its been in the woods for a while, but looks to be in pretty good shape.?
Ihad a 620 A H that looked alot like this . Main frame , lift scissor , crazy wheel , axles , colters , all look the same only difference is the bottoms I had NU bottoms . Mine was 4/16s . hope this helps .
You can clean that rust off best by using a 4 1/2" angle grinder with a thin cut-off disc..
Safety glasses and dust mask are needed..
Hold the spinning disc at about a 30 degree angle to the steel and move the disc like you are using a putty knife..
You probably won't need more than 4 Thin Cut-off discs to do the cleanup..
The disc will not harm the steel, but clean the rust off..right down to the black oxide under the rust and that will scour off nicely..
I suppose you could use a medium "Flapper Wheel" to dress it up, but I don't think it is necessary..
