Late A thrust washers ? Did the 60 use them ?
36 A
Installed a crank with sleeve type mains . No shinning is nice but it has thrust washers . Never seen this on an A . Did the 60's have the same thing ? One was cracked so I'm looking for one .
I would look into that... the 620/630 has much larger Main Bearing diameters...the rt side main is a full 4.000" !!!
Very late A with 1 piece bearing, very late G with 1 piece bearing, 60, 620 and 630 all use 2x A4398R thrust washers.
