TractorLinks.com
Show Parts for Model:
4020 block heater
MRogersII
11-13-2017 17:11:40
Can someone tell me the best place to install a block heater? I'm finishing a rebuild and don't see a place for one. Thank you
Michael
buickanddeere
11-15-2017 06:59:17
 Re: 4020 block heater in reply to MRogersII, 11-13-2017 17:11:40
Correction, what was I thinking. heater level lower port level with or lower than the lower port from the block.
David G
11-15-2017 04:48:37
Wherever you pipe it, make sure the tank is below the lowest point in the water jacket so it can circulate correctly.
buickanddeere
11-14-2017 04:33:57
. Top of coolant heater is pipes to the highest coolant port on the engine side of the coolant thermostats.
Bottom of coolant heater is plumbed to the lowest port on the engine block. Heater can not be above or below engine ports .
Tx Jim
11-14-2017 03:04:55
Factory engine heater plumbed into left side of block where 1/4'' drain cock is located & RH side of cylinder head(pipe bushing 3/4'')
newgenjdcollector
11-13-2017 19:27:45
The canister heaters work well on the pre console 4020s
MRogersII
11-13-2017 18:46:09
1968
coonie minnie
11-13-2017 17:38:12
I'm guessing yours is not a 71 or 72 with the knockout plug in the block (left side).
Usually on earlier ones they are tapped into the block drain plug ahead of the starter, and fed to the heater mounted on the right side by the oil cooler. From there a line is run to one of the plugs in the head, or can be tapped into the top of the oil cooler.
I'm sorry I don't have a picture, but have 3 here set up like that.
Bob Harvey
11-13-2017 17:14:24
There is a spot , if you look in the manual.
