Will a JD 730 two cylinder diesel tractor operate a one way cylinder by only hooking up to one of the rear remotes on the tractor? Looking at buying a pull type bush hog that the rear wheels/lift operates with a one way cylinder. I have never tried to operate a one way cylinder on my 730. The bush hog is several hundred miles from me. I realize the cylinder/hoses can be replaced with a two way setup. The weight of the bush hog will push the fluid back just not sure the 730 hydraulic system will allow the fluid to return in the same hose. I think the one way cylinder will work on my tractor just need someone to verify before committing to buy the bush hog. Any information on this matter is appreciated.
Thank you, TPat
Thank you, TPat
