JD 2955 clutch slave cylinder
tractorsam
I have the 2955 split and have a few issues. The new clutch cylinder has 3 ports where the old one only has two. I take it we received the wrong cylinder? Is there any way to plug the third port without causing bleeding issues? Also does anyone have the torque for the flywheel and clutch mounting bolts? Thank you, Sam
Honestly I have no idea. This was what the dealer supplied
based on a phone call. Are the Deere parts books available
online? Not my usual colour. Thanks, Sam
The parts book shows 3 ports (2 out the top and 1 out the side) with a plug, L41876 and sealing washer, L39222 to plug the side port. The wording sounds like the original only had 2 while updated replacement parts have 3 ports. All versions sub to the latest number, al120029.
The spare hole should be plugged. LUK updated the cylinder years ago, I think because it is also used in other makes of tractor. It is not a Deere manufactured part.
