4020 with 3020 vin?? Need advice!
Leachman44
New User
Hello, i recently picked up a 4020 for a small farm yard and have run into a few issues that makes me question what this tractor really is. If any of you are able to decode this vin or can comfirm by the description or know what to check on the tractor to confirm that would be great! Vin on rear of tractor: T1113R 127736R,
Local john deere dealer told me it was a 3020 when i called for a range shifter arm but i thought 3020 were all 4 cyls?
Tractor has:
6cyl engine, no vin tag, vertical mounted pump, large body injectors,
12v, looks original not converted
Diff lock
Side hyd controls by right hip
Pto control on LHS of dash
Is it possibly this tractor has been peices together? All connections between trans and engine look OEM nothing hacked together by any means. Any help on this is greatly Appreciated
4010 and '64 4020 had big injectors
and 24V
Pto lever on LH side on 4010.
No diff lock on 4010.
You are probably right.... pieced together!
