3020 hydraulic pto?
trak
on the front of the crank, going out to the hydraulics, have clunking, looks like their may be a couple rubber bushings that need replaced, around 4-5" apart, looking for what they are called, maybe some replacement tips...
its the hydraulic pump shaft coupler, clunking where the bolts go through,, I might be able to put a fix on it
Picture is based upon an early JD3020
All the part numbers and diagrams are on jdparts.com
When the bushings get beat through the
pins will beat into the halves. Would
then require pins, bushings and halves.
