Switching to one piece main bearings
36 A
Has anybody ever swapped out two piece main bearing housings and put in the newer style ? It's a 51 A and I junked out a 52 A got a really nice crank and bearing housings . The I T Manuel says you can but doesn't say if the oil lines will work . The oil lines look different at the pump and housings .
If the housings bolt up I would make oil lines if needed. Maybe just some careful rebending of the lines or use the ones from the parts tractor ?
The main bearing oil lines out of the 52 parts tractor will fit right in the 51.
