Hood and manifold for 820 3 cyl
bv
Looking for good straight hood for a 820 3cyl tractor with the muffler out the hood, also is the manifold the same for the muffler out the hood and the muffler under the tractor? What kind of oil do recommend to use in these tractors throughout?
You should be able to use a 820,830,1020,1520 or a 1530 hood as all were three cylinders. Some of the yellow industrial tractors such as the 300,301 and 302 used that hood as well. I think the manifold is available aftermarket (check this website as they sell parts). If you find a good hood with underneath exhaust with patience you can do a good job of cutting it for the up right exhaust. Tom
Thank you guys for the help, do you just turn the manifold over for the upright muffler?
