4630 powershift trans pump
fdt860
My friend has a 4630 with wore out trans pump. The housing seems to be worn some.
How do you fix this? New housing + gears?
I cannot see oversized outer gear in JDParts, do they exist, so we can bore a little bit the housing?
Thanks for the answer.
We are at $1200 for the housing at JD and $185 and $205 for the gears aftermarket.
A-AR90959 Hydraulic Pump - TRANSMISSION PUMP ADD 903.11 USD
This is not a better deal...
