520 oil issues
Now that is a weird one ? Like the other poster said it is usually engine oil into the trans. Are you sure it is not power steering oil ? it sort of smells like gear oil ?
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">Are you sure it is not power steering oil ?[/i:654c4848f0][/b:654c4848f0]</font>"
Just curious about how power steering oil might get into the crankcase.
One of our Model 70s "uses" power steering oil and there is no evidence of a leak on the tractor or the ground under the tractor.
The pump is on the fanshaft. So it can go into the fanshaft tube and then into the engine if the pump seals are bad.
(quoted from post at 12:51:31 10/30/17) Now that is a weird one ? Like the other poster said it is usually engine oil into the trans. Are you sure it is not power steering oil ? it sort of smells like gear oil ?
Does smell like gear oil I just rebuilt pump with all new seals but will have to check power steering level
(quoted from post at 17:06:23 10/30/17)
Found the issue 2 gal of gear oil in 1st gear reduction cover drained and flushed trans and cover filled with proper amount problem has not returned
