JD 2020 Aux Rear Hydraulics
Just buy the complete setup for a salvage yard. Your looking at around $750-$1000 for the valve/line/rear couplers. Boot Heal tractor parts usually has them. The setup would be the same for many of the JD utility tractors.
Boot Heel Tractor parts:
http://www.bootheeltractorparts.com/
Boot Heal
I agree with JD Seller on installing factory scv but if one didn't desire to spend $750 one could install a loader type valve on a bracket with breakaways. Another advantage to spool type
valve is it's not a s complicated to repair as JD's OEM poppet type valves
I can't see jd sellers reply for some reason....can you provide a link explaining that? I'm new to hydraulics.
Thanks
(quoted from post at 07:03:11 10/28/17)
Thanks
JD included the name and link of a YT competitor, and most such references result in failure of the post to show in Modern View. Switch to Classic View, and you'll see JD's mention of B O O T H E E L parts.
Joe YT DOES not sell used tractor parts. So I did not post a link to a competitor but the filter thinks so. LOL
