waterman74
Hello,
Can someone verify the lift capacity for a John Deere 2020 tractor made in 1968. I got the following from a website......
"""In 1967, the very first John Deere 2020 Tractors went out. They were produced until 1972. .... The type II 3-point hitch is very reliable, capable to lift 4498 lbs [2040 kg]. It is also worth noting that the live rear PTO runs at 540 rpms. The John Deere 2020 has a closed center hydraulics system with a 10 gal [37.9 L] capacity. The pump does the job pushing 12.4 gpm [46.9 lpm] fluids in the hydraulics system."""
4498 lbs seems awfully high. In fact, according to tractor data the 4020 only lifts 3790lbs and its a much bigger tractor.
I'm looking at buying a 3000lb no till seeder and need to know. I have a 1000lb rototiller that it lifts fine.
Thanks,
Thanks,
